Rock 40 - You are indeed jumping pin 16 to 18 with the resistor. I put my resistor as close as possible to the connector so that it didnt get damaged behind the radio. My 4runner already had the aux input jack so mine just plugged in via the adapter harnesses and the info on this forum. I'll see if I can dig up the pinouts.
I found this from a person pitting a T1819 into a 4Runner:
T1819 radio connectors:
10pin connector:
1 -> front right +
2 -> front left +
3 -> ACC ignition +12V
4 -> battery +12V
5 -> front right -
6 -> front left -
7 -> ground
8 -> (antenna amplifier + output) now on antenna connector, you have to splice in here
9 -> amplifier control + output
10 -> illumination + input
6pin connector:
1 -> rear right +
2 -> rear left +
3 -> rear right -
4 -> telefone mute input, connect to ground to mute radio
5 -> illumination - input, connect to ground if not connected to rheostat (instument illumination dimmer)
6 -> rear left -
12pin connector CD changer, SAT, ...:
1 -> audio signal shield (ground) for pin2+3+4+5
2 -> audio R+ in
3 -> audio R- in
4 -> audio L+ in
5 -> audio L- in
6 -> mute in
7 -> ground
8 -> not used, unknown
9 -> AVC-LAN TX+
10 -> AVC-LAN TX-
11 -> ACC ignition +12V (I think it is an output, not 100% sure)
12 -> battery +12V (I think it is an output, not 100% sure)
USB connector:
-> on T1814 and T1815 it is a JAE MX39004NQ1 connector (USB type A receptacle style)
-> you have to use a Toyota factory cable assembly or solder an USB cable directly on the connector pins
-> on T1819, I think it is a JAE MX39006NQ1 (not sure) connector (USB type B plug style)
-> factory cable will not fit, use PT546-00120-US or solder an USB cable directly on the connector pins, don't have another Toyota part number
Antenna connector:
-> new style (similar to FAKRA connectors), dual antenna input, antenna amplifier + output (splice in 10pin connector pin8 or use adapter harness PT546-00120-AD)
28pin connector, replaces 20pin + 8pin connector on T1819:
1...28 -> to be figured out
2 RCA connectors:
-> pre-amp output for subwoofer, monoaural, L+R have the same signal, no fader/balance, master volume works, subwoofer level adjustable
Vehicle harness connectors:
20pin steering wheel controls, speed signal, AUX IN connector:
1 -> not used
2 -> not used
3 -> SPD, speed signal in
4 -> not used
5 -> not used
6 -> SWG, steering wheel controls ground
7 -> SW1, steering wheeel controls switched resistors input 1
8 -> SW1, steering wheeel controls switched resistors input 2
9 -> TX1+ to multi display TX2+, wire twisted with pin 10 wire, I think this is not used
10 -> TX1- to multi display TX2-, wire twisted with pin 9 wire, I think this is not used
11 -> not used, control for factory external audio amplifier
12 -> not used, control for factory external audio amplifier
13 -> not used, shield for pin 11+12, control for factory external audio amplifier
14 -> not used any more, AGND for older SCION headunits
15 -> ARI, AUX R+ IN
16 -> ASGN, AUX RL- ground
17 -> ALI, AUX L+ IN
18 -> AGND, audio shield (ground) for pin 15+16+17
19 -> AUXI (open 3.1V), jack pluged in 2,7kOhms to AGND (AUX IN enabled) <-> jack not pluged in 15kOhms to AGND (AUX IN disabled), use a 3,5mm stereo jack with build in switch and series resistor 3.3kOhms and parallel resistor 15kOhms)
20 -> used, but don't know what it is
8pin 3.5mm Stereo Jack connector - old SCION headunits w/o USB:
1 -> ALO, AUX L+ OUT
2 -> ARO, AUX R+ OUT
3 -> ASGN, AUX RL- ground
4 -> AUXO (open 3.1V), jack pluged in 2,7kOhms to AGND (AUX IN enabled) <-> jack not pluged in 15kOhms to AGND (AUX IN disabled), use a 3,5mm stereo jack with build in switch and series resistor 3.3kOhms and parallel resistor 15kOhms)
5 -> AGND, audio shield (ground) for pin 1+2+3
6 -> not used
7 -> not used
8 -> not used
5pin 3.5mm Stereo Jack connector - new SCION headunits with USB:
1 -> AUXO (open 3.1V), jack pluged in 2,7kOhms to AUXG (AUX IN enabled) <-> jack not pluged in 15kOhms to AUXG (AUX IN disabled), use a 3,5mm stereo jack with build in switch and series resistor 3.3kOhms and parallel resistor 15kOhms)
2 -> ASGN, AUX RL- ground
3 -> ARO, AUX R+ OUT
4 -> ALO, AUX L+ OUT
5 -> AUXG, audio shield (ground) for pin 2+3+4
8pin microphone connector (not sure about the pinout):
1 -> TSW-, connect to ground (6) to tell the radio that there is a mic / enable Bluetooth
2 -> MIC+
3 -> MCVD (+5V output to power the mic amplifier)
4 -> not used
5 -> MIC-
6 -> audio shield (ground) for pin 2+5
7 -> not used
8 -> not used
