- Year
- 1963
- Vehicle Model
- 45 Series
- Location
- United States
- Mileage
- 79596
Is drivable now but lacks a working horn and hazard lights. Titled as a 1964 as was the custom back then. Actual mileage unknown. Clear title.
Parts replaced or rebuilt since project started in 2020, list of some of the work done.
- F155 motor (1970 approx) rebuilt, done by friend who is a retired Porsche 911 tech, machine work by Motor Works Inc. in National City CA, now has about 500 miles on it
- 3 speed trans and transfer case – bearing kits installed
- New starter, distributor, coil, Weber carb, fuel pump, clutch kit, thermostat housing, radiator, power steering pump, water pump, temp sender, oil sender, coolant hoses, thermostat, motor mounts
- Rebuilt alternator, new external regulator
- Many brackets and parts under hood cleaned up by sand blasting, then painted using high temp paint and high temp clear coats
- Installed used FJ60 power steering box with kit from Iron Pig Offroad
- New parking brake cable, throttle cable, various brake lines, master clutch and brake cylinders, slave cylinders for clutch and rear brakes.
- Power brakes from remote MG style booster to front (disc brakes previously installed – looks to be the JT Outfitters GM conversion, original drums in rear).
- New head lights, front turn signals and running lights, battery and tray
- 5 New OEM rims and hub caps, painted Dune Beige same as fire wall with ppg paint, front wheel spacers per previous owner, new Toyo mud terrains
- New steering ball joints, new front leaf springs (Old Man Emu), rear view mirror, front shocks
- Used 4 speed transmission
- Doorstop repair kits
- Front knuckle kits
- Skid plate – from later year 40 series
- wiper motors
- has storage box under drivers seat with a jack
- several of the old replaced parts etc, brake pedal, headlight buckets, …
