cruisedeisel
Toyota's for life
Well I have been following the thread in the 60's section on how to upgrade your power steering pump for a 2f gasser.
I have obtained a saginaw pump from a 90's chevy pickup. I will find a way to mount it and connect all the hose's with as much detail as I can pass on.
If you have 33" tires or bigger and have any kind of locker in your front end. You should know that the stock yota PSP sucks when your hubs a locked.
I hope this can help and shed some light on all with a 3b. Note that I am using a 3b that has power steering already. If you are setting up a 82 and prior 3b without power steering. You will need the PSP bracket, pulley from the pump and alternator since the alternator is slightly different.
