Since we got way off topic on a power steering box rebuild, discussing my Saginaw conversion, I thought I would post some numbers here related to the conversion.
Hose (Got from RockAuto):
power steering hose from a 1985-1986 Chevy C10 Pickup 4.3L engine, with the following part numbers:
EDELMANN Part # 71270
GATES Part # 356240
ACDELCO Part # 36356240
This hose is a 16mmx1.5 male O-ring hose, both ends.
Auto zone numbers are 71270 for the hose and 7064 for the pump. You need to get a cap for the pump, too.
Use ATSCO 7064 pump which has a M16 x 1.5 pressure port.
Uses Reservoir cap DORMAN Part # 82581
The pulley is Pulley $15)
https://www.surpluscenter.com/item.asp?catname=powerTrans&item=1-BKH60,
but I think a better one is
https://www.surpluscenter.com/item.asp?catname=powerTrans&item=1-BKH57, since it will make the pump spin a little faster.
Pulley Hub for ATSCO pump: ($5)
http://www.surpluscenter.com/item.asp?item=1-2913-75
I can supply the patterns for building the bracket, and I might even be convinced to build a 16Mx1.5 Female inverted flare to 16Mx1.5 Female O-ring adapter out of 6061-T6 AL. Not sure I want to anodize it again, though.
GATES Part # 356240
