Thanks for that - Went to
http://www.discounthydraulichose.com, and they don't have a MIX-90-06-16MM end that I can find. It would be nice to find an adapter that isn't a daisy chained beastie.
Kon'nichiwa,
I have found out that the JIS (Japanese Industrial Standard) uses a 30* flare face angle (as opposed to the 37* flare face angle for the JIC or AN).
But, according to this information (see below), the threads used on the JIS are the same as BSP (British Standard Pipe).
However, another japanese standard, named Komatsu, is essentially the same as the JIS (so Komatsu also uses the 30* flare face angle) expect that it uses metric threads.
So, I am beginning to believe that the OEM fittings (on both the female port and male hose end) for the pressure port on the OEM FJ6X steering box are Komatsu fittings.
Which would mean searching for a Komatsu male 60* seat or Komatsu male 30* inverted flare to go over that 3/8" pipe (aka -06) 90* elbow...
Japanese Industrial Standard: This coupling looks similar to MJ and FJX fittings. There are two major differences - the threads are BSP and the seat angle is only 30-degrees instead of 37-degrees.
Komatsu: This fitting looks similar to the JIS fitting. The major difference - metric threads instead of BSP.
Japanese Tapered Pipe Thread: This connector has the same thread as BSPT and will mate with BSPT connectors. It will NOT mate with the BSPP female swivel because it lacks the 30 degree inverted seat. Flanges for most Japanese hydraulic equipment - including Komatsu - are standard Codes 61 or 62 except for -10. Some drop dimensions are slightly different and the O-ring dimensions are different. Be sure to use the SAE O-ring in the SAE flange when replacing a Komatsu flange.
Great Britain BSPP (British Standard Pipe Parallel): BSP is the most popular thread end in Great Britain. These threads are either parallel (BSPP) or tapered (BSPT). The male BSPP will mate with a BSPP (parallel female or a female port). The male BSPT will mate with the BSPP female swivel. The male has straight threads and a 30-degree inverted seat. The BSPP female has straight threads and a 30-degree inverted seat. The female port has straight threads and spotface. The seal on the port is made with an "O" Ring or a soft metal washer on the male. The BSPP connector is similar to, but not interchangeable with our FPX. The thread pitch is different in most sizes, and the thread angle is 55-degrees instead of the 60-degree angle found on NPSM threads.
BSPT (British Standard Pipe Tapered): The BSPT (tapered) male will mate with a BSPT (tapered) female and the BSPP female swivel. The BSPT male has tapered threads and a 30-degree inverted seat. The BSPT connector is similar to but not interchangeable with our MP. The thread pitch is different in most cases, and the thread angle is 55 degrees instead of the 60-degree angle found on NPTF threads.
Neither the British parallel pipe or the British tapered pipe has true metric threads, although many people find these threads "foreign" and conclude they must be "metric.”
http://www.gates.com/products/indus...s/hydraulic-couplings/international-couplings
