This is my first serious post regarding the 40 I recently purchased. When I inspected it, I found it to have a somewhat questionable Saginaw conversion. I don't readily have access to the cruiser so I'm going from pics I took to explain what I have.
During all the searches I've done here regarding the conversion, I've never seen this type of setup. My concern with it is that it is canted at an angle and has an unusual mounting setup.
What is not shown is the Borgeson joint at the snout of the unit which is attached to a solid shaft going towards the steering column.
The questions I have are:
Is the angle of the Saginaw unit a real concern?
Is the angle of the shaft coming off the borgeson joint a concern?
If I leave it as is what potential problems will I run into?
