Can you see a graceful way to get some ATF into those upper corners without cutting in? Could you squirt some atf in there with a syringe and a thin hose threaded in from the strengthening holes in the underside of the roof?
Ah, I've just never run into that much trouble with the D pillars, seems like every A pillar is an issue. Lets put this on hold for a bit and I'll actually take a section cut from the old d pillar so we can see exactly what there is to deal with back there.I'm not familiar with Oregon.. It's hot a steamy here which leads to water collecting in the areas you just fixed. A and D pillar corners were the roof pinches onto the pillars. I just drilled weep holes on those spots. It helps the roof "breath" or drain the collected humidity/condensation.
Yup, I thoroughly clean and prime everything I can get to.Those area that become enclosed after welding, I usually hit with at least some weld through primer before closing up. Just to have something on the metal.
Absolutely, as long as the headliner is out of the way you can squirt the stuff in where you need it all around the truck.Can you see a graceful way to get some ATF into those upper corners without cutting in? Could you squirt some atf in there with a syringe and a thin hose threaded in from the strengthening holes in the underside of the roof?
Plenty of time spent working on bikes, but I never made my own frame..... yet.
There's really not much upholstery to work with, I've obviously got no tailgate or side panels to worry about, the seats are from a Subaru but I might find a new option there, my door panels are in great shape and we didn't have any carpet.Looks like you're making good progress, going to clean up the rest of the upholstery while it's all apart too?
FWIW pm me if you ever need places/shops to visit and Geek Out, I'm still connected w/ that industry even though I've finally moved onto other career and life goals.![]()
Good work Kevin!! Love the FJ60 seat chair![]()
Got to work with what you have!
Hey Tony!Hey Kevin,
Looks like you've made huge progress since collecting the truck from Bend! I haven't been on Mud for a while, but I'll keep an eye on your build now.
Cheers!
Ah, I've just never run into that much trouble with the D pillars, seems like every A pillar is an issue. Lets put this on hold for a bit and I'll actually take a section cut from the old d pillar so we can see exactly what there is to deal with back there.Originally Posted by beaufort-fj60
