- Thread starter
- #101
Also got to do a bit of mechanical work (which I much prefer) since I am swapping in a 62 case that I have here (better bearings and the larger idler shaft). The 62 case is vacuum shift and I'll be staying with manual so you have to drill/tap out for the lock ball that is not there on the 62 cases.
Pics are out of order but you can see that I finish off the hole with a reamer rather than a drill, if you can get your hands on one this leaves a much cleaner inner hole, which is good since the shift shaft uses it as a bore. These reamers are really expensive though, I was lucky to pick a few up at an auction years ago.
Here you can kinda see the inside of that bore, fairly clean.
And since this gets bolted to a 5 speed manual, don't forget the oiler cup on the front of the case!
And... I drilled out and tapped for a proper case vent line, this will be plumbed up to the firewall.
trying to save myself the aggravation)
