Catching Neutral
GOLD Star
Anyone know where I can source a bolt kit for the running board?
I've searched for FJ40 Running Board Bolt Kits as well with no luck. I read through the entire "Bolt thread" and there is no mention of bolts for the late 1972-1978 style running boards. So, based on what I removed from my June '72 FJ40 with the actual diamond plate welded on to the running board design (which is no longer available), and the Toyota parts diagram, here are the original parts with part #s:Anyone know where I can source a bolt kit for the running board?
Agreed but what's the fun it that? Plus the Hex heads on the ACE Hardware bolts would probably be 13mm. I did send an email to @davework which I think is Overland Metric to get some of his tasty Marine Grade Stainless hardware but haven't heard anything back yet. I'll also send him a note through iIf you are talking about the six bolts that holds the running board to the tub & front fender, I just used some stainless steel M8 units. Probably can get them ACE hardware as needed....But @davework stainless steel units would be much better!
Agreed but what's the fun it that? Plus the Hex heads on the ACE Hardware bolts would probably be 13mm. I did send an email to @davework which I think is Overland Metric to get some of his tasty Marine Grade Stainless hardware but haven't heard anything back yet. I'll also send him a note through imud. Thanks!
x2 (1 ea. side) JIS M10x1.25x30mm carriage bolt (#90112-10007) discontinued or (#91665-41035)
The M10 now goes up from the bottom through the frame support bracket and connects to a captive nut on the bottom of the running board.Where is this single M10 bolt used? Need to pull out parts diagram.
