LAMBCRUSHER
I have seen in other threads the spec for the rear main seal of 2F and 3FE engines. the 2F seal is 100mm inner diameter, while the 3FE is 105mm inner diameter; both with 120mm outer. this was the spec for the seal, FWIU, and I am not certain if it is the spec for the journal itself...
I have a Toyota reman 3FE that I am rebuilding. it has some miles on it. It has .50mm over slugs, and .25mm under mains and rods. The mains and rod are going to be turned to .50mm under, and the block will grow to take some new(er) fatter pistons. I believe the rear main journal has been turned and sleeved. I forgot to hit it with my calipers this morning, but the 4" mic was to shy, and by more than a couple mm, so I'm inclined to think it is larger than the 105mm diameter that the seal is specd for.
In lieu of measuring it this afternoon, has anyone got a stock 3FE crank they can measure for me, or confirmation that the seal spec correlates to the journal diameter? I'd also take the spec for a 2F rear main journal if anyone knows that.
Thanks, Mud.
Thanks, Mud.
