2fpower
I need help. I am converting a LS into a 1992 BJ73 and I did a horrible job when I tore out the old engine, so needing help tracking down the temp sensor wire and the engine oil pressure sensor wires.
There are three wires coming from near the battery on the exhaust side of the engine. The longest one I believe goes to the alternator, and there are two shorter wires on that same harness. one is white with a light bluestripe, the other is yellow with a green stripe. What do these go to. I thought gauges, but they did not test out.
On the other side of the engine, I have a big harness connector that I can't find any note of what it went to. Is the oil pressure sender or the water temp sensor on that side?
Thanks in advance,
k
Thanks in advance,
k
