Thanks for the info. I believe the bad batch had come out in 2021 and was limited to about a year or a bit less. I ordered mine directly from the Toyota stealership in Washington state, and they ordered it from their central warehouse, I did ask them about that but they said it was newer stuff... Not sure??So there was a bad batch of AHC fluid last year and some notable examples here on mud of folks burning up their pump. Given you where just in there it could be that 1) you had bad fluid or 2) debris was introduced or dislodged. I concur with others that if you dont hear the pump and dont have a leak it's likely the culprit. If you / the shop pull the pump, there is a screen between the resivoir and pump chamber that will tell you for sure what happened.
Wouldn't bother with 5th accumulator personally.
At least you live up to your username and the vehicle you drive.That's not how I read it, but I wasn't looking for an opportunity to tell someone that I was better than them because I bought a 'real' Land Cruiser unlike them. That's way superior 'dontcha know. Because it came from the exact same factory and was assembled by the exact same workers, but it's got some brand cachet and a totally way better conventional suspension.
Congrats on your TLC purchase! You got a 200 just like us!
(Edit - I forgot one small thing. op can’t buy a TLC 200 even if they wanted to. Only LX sold in Canada.)
Who would ever think an unwashed 2009 LX had anything to do with my self worth? It’s a car my man. It’s no better than any other way to get from A to Z. Worse than some, better than others. I could have cared less which brand of 200 I bought. Didn’t care 6 years ago, and don’t care now. Don’t care what brand you bought either.At least you live up to your username and the vehicle you drive.
Bravo
I’m not sure if the pump plug is behind the fender fascia, I don’t have that fascia on anymore so I can see mine, . It is tight against the passenger rear inside rail, near to the trailer plug breakout. it is possible to jumper the pump with 12v directly. So you could try that. My pump has stopped working twice, both associated to that plug being a tad loose, once after a short term body lift, and once a year or so later for no reason. Both times simply making sure it was firmly seated restored function. I don’t think this is your roost cause though.Thanks for the info. I believe the bad batch had come out in 2021 and was limited to about a year or a bit less. I ordered mine directly from the Toyota stealership in Washington state, and they ordered it from their central warehouse, I did ask them about that but they said it was newer stuff... Not sure??
It came out of the Japanese (kind of cool looking) 2.5L tins. I still have some leftover.
In any case, If replacing I'll be sure to use fresh (new) anyway. Thx for the input. I'll likely find out on Wednesday during the diag by the shop.
What do you mean whether or not I see the AhC section in the MID (H normal L)? Are you asking whether or not I can see the AHC status in the driver's side display? Not sure that MID means (perhaps multi display or something?) I will check again, I'm pretty sure it just says "Check AHC system", and the icon shows it in Low mode. Are you saying that if that icon doesn't snow up, then it might be the AHC computer instead of the pump?I’m not sure if the pump plug is behind the fender fascia, I don’t have that fascia on anymore so I can see mine, . It is tight against the passenger rear inside rail, near to the trailer plug breakout. it is possible to jumper the pump with 12v directly. So you could try that. My pump has stopped working twice, both associated to that plug being a tad loose, once after a short term body lift, and once a year or so later for no reason. Both times simply making sure it was firmly seated restored function. I don’t think this is your roost cause though.
There are threads on here to get the FsM, so then you can find the plug pin out.
Another potential culprit is the AHC computer. Do you see the AhC section in the MID (the H normal L diagram)? That goes away when the AHc computer is MiA.
Have you checked the ahc fuses?
(Edit - don’t buy more globes, that is almost certainly not the issue)
This is exactly what happened when my pump failed, there could be an ECU issue as well. Have you hooked up techstream and tried to reset the error?What do you mean whether or not I see the AhC section in the MID (H normal L)? Are you asking whether or not I can see the AHC status in the driver's side display? Not sure that MID means (perhaps multi display or something?) I will check again, I'm pretty sure it just says "Check AHC system", and the icon shows it in Low mode. Are you saying that if that icon doesn't snow up, then it might be the AHC computer instead of the pump?
Yes, if the Ahc portion of the driver display in the speedometer disappears that is a sign the Ahc ecu isn’t getting power or a fuse is blown for the ecu. Seems like since you have Ahc display that is not the case.What do you mean whether or not I see the AhC section in the MID (H normal L)? Are you asking whether or not I can see the AHC status in the driver's side display? Not sure that MID means (perhaps multi display or something?) I will check again, I'm pretty sure it just says "Check AHC system", and the icon shows it in Low mode. Are you saying that if that icon doesn't snow up, then it might be the AHC computer instead of the pump?
Bravo
I agree. And I apologize for my part in it.The back-and-forth forth forum boy bitching is helping nothing at all.
Nope, not sensor lifted, nor do we put too much weight into it. Don't tow heavy either (have a diesel 1 ton for that job).How much additional weight is on your LX570? Are you sensor lifted?
forum.ih8mud.com
I heard it was easy to download, but I searched a few threads previously and it sounded a fair bit technical to get it setup etc... Which for me is a bit over my head. I also don't have a reader atm. Anyway I'd rather someone that actually knows what they're doing look at it. (which isn't really me).I'm really surprised how hard of a time you are having finding someone with techstream. You can get a questionably legal copy going on a VM in like 5 minutes with a cable you can buy on amazon:
FAQ - How-To: TechStream In 5 Minutes
forum.ih8mud.com
I'm using this on a VM on a macbook air and it works fine
you're fine to drive on the springs.I heard it was easy to download, but I searched a few threads previously and it sounded a fair bit technical to get it setup etc... Which for me is a bit over my head. I also don't have a reader atm. Anyway I'd rather someone that actually knows what they're doing look at it. (which isn't really me).
One question I have is, how bad is it on the bump stops to drive around for a bit like this? I have to drive 80kms (flat highway) one way (160km return if not fixed) the way it is. It's not a bad ride at all just smooth highway, but when you hit bumps then for sure you feel it more. Will it do significantly more damage if I do this? Is it worth the extra significant cost to tow it in? (it's a hefty bill to do that, so want to know for sure first)
How was your impression of Regency Lexus Vancouver? Did you get to talk with the tech that worked on your car, and do they seem knowledgeable and experienced with the AHC system? Or was this their first project with the AHC system? Sry for all the questions, I'm asking because I'm looking for a reliable place in the Lower Mainland to service my AHC system too. There aren't that many 200 series around our area.so the dealer (Regency Lexus Vancouver, BC) cut their repair hours in half which was a MASSIVE help
Regency went out of their way to really help me, likely just for my circumstance given there was much corrosion and the job started ballooning far beyond what they had quoted me. They even provided a free loaner car for a few days (2025 NX). Yes, it cost well into the thousands, but that being said most of the lines are all new (at least all the rear lines) - I might look into the front lines and new globes in 4 years time when the next fluid flush will be due.How was your impression of Regency Lexus Vancouver? Did you get to talk with the tech that worked on your car, and do they seem knowledgeable and experienced with the AHC system? Or was this their first project with the AHC system? Sry for all the questions, I'm asking because I'm looking for a reliable place in the Lower Mainland to service my AHC system too. There aren't that many 200 series around our area.
Also, I'm assuming the labour bill is still in the thousands even after they cut their hours in half? Pls don't feel obligated to share if you don't want too!
