Hey guys,
First time poster, long time browser!
I have a ‘00 Lx470 that I bought about 8 months ago and up until this week, it’s been running amazing! It spent the majority of its life in the Palm Springs area before I brought it up to Canada so besides some very dry seals and a sunburnt roof, it’s a really clean truck!
I recently crossed the 200k mile mark and all of sudden I started experiencing issues and wondering where to start troubleshooting.
Before I start, I just want to say that I have spent hours digging through the forum as there are quite a lot of posts that seem similar to my issues but feel it might be good to lay out what I’m seeing incase there are any clues that I might not see and would be obvious to a seasoned 100series vet! Lost not lazy! LOL
To begin.. here is a series of issues that have somewhat popped up. They might be related or be completely separate problems but I think it best to lay them all out just incase.
About 3 weeks ago, I noticed a bit of a lag when the truck would go from 4th to 5th gear.. this was always around 60mph @ 2000rmp. As I would accelerate thru this range the truck would almost stutter or bog for just a second as if the fuel was cut off. I’d back off the gas and it would correct itself right away. If not, it would result in a bit of hard knock as if the clutch was enganged and quickly slipped off.. I thought it was transmission related but when I brought it to a transmission specialist, they said everything from a transmission perspective was rock solid. They did scan it and came up with the TWO codes:
P0430 B2 & P0470 B1
They cleared the codes and I continued driving for a few more days before taking to a mechanic friend to look at.. He drove it around, rescanned it and found nothing wrong nor any codes popped up.
I took it the following week on a trip about 200miles to the in-laws for Christmas and the truck was running great. I parked it for a few days and when I went to start it (cold), it really really struggled.
The engine would turn but it just catch and fire up. I tried about 10-15 times and finally it started!
Some of the cranks would result in the battery voltage dropping below the 1/2 mark on the gauge and it wouldn’t be able to turn the starter. Some of the cracks would see to catch so the starter would stop but the engine would sputter and die. If I pumped/press the gas, it would eventually fire up!
Once I got it started, I had to drive it back home (about a 200mile trip) and it was super smooth. No lag, loss of power or lack in the throttle at all. It was super smooth and cruised at 70MPH... BUT as I got closer to my house in more urban traffic, it was a nightmare.. As I approached a stop sign or red light, the RPMs would fall as low as 450-500 and then the truck would stall. I would still have power as all the dash icons would light up when it stalled and generally, I would be able to put it in park and fire it back up in one or two tries..
I managed to limp it back to my house (yesterday) and this is where I’m currently at.
From what I’ve read, the “low Idle to stall” and “crank & non-start” seem to be pretty common.
I started digging around under the hood but truth be told, I’m not a very mechanical advanced and this engine is far more electronic than I’m used to so I’m a bit nervous where to begin.
The good news is, the engine bay is super clean and with out testing via a meter, the obvious contacts look clean and free of corrosion. I check the fuse box to inspect everything related to the fuel pump (fuse & EFI relay) and they seem okay. ( I just visually inspected them for contact build up to corrosion but once again pretty clean..) I pulled the air intake to inspect the Throttle body valve to see if it might be jammed open.. (needs a cleaning but seemed to function.)
For what I can manage on my own, I’m going to buy a voltage meter to start actually testing all the relays and the fuseable link attached to the + on the battery. I’m also going to get a cleaner for the ETV & MAF to rule these all out but any other suggestions or thoughts would be awesome..
If my battery wasn’t carrying a significant charge, could this be the cause? ( I’m not sure when the PO last changed it?) I could see how this might effect the starting but would a weak battery effect the idle?
Concerning EFI relay, is there a way to test to see if it is working correctly? The problem feels very much fuel related but that’s based on limited knowledge.
Any advice would be great!
Keep in mind that I have limited skills ( mixed with lots of determination) but anything complex or more advanced i will pass on to my mechanic if I can’t solve it myself!
Thanks
J
P0430 B2 & P0470 B1
Thanks
J
