Rough ride- where to start? (2 Viewers)
Macon, GA
First, I have searched the forum and cannot seem to find an answer. If I am missing it I apologize. I have a 2007 LC with 170k miles that is beginning to have a rough ride. By that, I mean that I seem to feel every bump in the road, mostly when driving slow. My question is, where do I begin looking to troubleshoot? Do I begin with the shocks or AHC, or is it likely a combination of both due to the age. Also, it is completely stock with OEM size Michelins. No lift.
Any help is appreciated.
First, please put your truck info in your signature line. It'll save a lot of time.
Next, download the service manual for your year and model from the Resources section.
Finally, crawl under the truck and make a note of anything related to the suspension which is not metal, and note its condition. Remove the front wheels and do the same thing. If you see any damaged metal parts, take care of those before doing anything else.
» Replace the AHC fluid and bleed the system. Download Techstream and check your system for leaks and proper operation. You do not need new hydraulic struts unless they are leaking. If they are, replace them first. Techstream will (likely) indicate whether your accumulators are good or not, as well as the pump. Replace as necessary.
» Decide whether you want OEM parts or aftermarket parts and, starting at the front of the truck, replace everything rubbber, in order of most age/use damaged.
You don't have to do all of this at once; it can be a long term process. Once you have replaced the shocks or serviced the AHC system, as appropriate, and replaced anything obviously damaged or worn beyond obvious usability, prioritize the replacement based on whether you have ride or handling concerns.
» Ride concerns (in order of priority for effect):
1. body bushings; numbers 2, 3 & 4 first, then 5, then 1 & 6 if you feel up to it; or do them all at once, if you have the money
2. seat pads; you have no idea how much difference this makes
» Handling concerns (in order of priority for effect):
1. Upper and Lower Front Suspensions; or ball joints if you're not using OEM parts – you cannot buy just the ball joint from Toyota. Replace these as a set; both sides.
2. Front Anchor Arm Bushing & Stabilizer bushings
3. Rear Upper and Lower Control Arm bushings & Stabilizer bushings. Replace these as a set; both sides.
4. Three (3) Front Differential bushings
5. Three (3) Engine mounts
Find the "ABCs of AHC" thread. Probably everything you could ever want to know and then some. I would not replace anything until you replace / bleed the AHC fluid and get the pressures in line.
Most likely you need new fluid and globes, but don't fire the parts cannon at it. Walk through the tune up process on the first page of the thread and go from there.
Hard agree with this. It's probably a failed (or failing) globe. But follow the process, do a graduation test and you'll find the culprit.
Unless the actuators (shocks) are leaking they don't need to be replaced, the have some valving internally, but the fluid can be replaced as part of a system flush
