Roof Rack Wire Routing (1 Viewer)
WTITW
Chandler, AZ
Website
www.wastingtimeinthewoods.com
How have you guys routed the wires for your roof rack electrical accessories? I'm getting ready to build harnesses for camp lights around the corners of my rack and I'd really rather not route through the cab and spit out the back only to extend the run all the way to the front of the cab again for the front lights. Anyone routed up the windshield without a snorkel? I can come out through the cowl seal behind the hood but I'm not sure how I can secure the harness to the pillar
My lights are mounted on my rack. Wiring runs into the rear hatch area. It's a fairly clean install.
My concern with running wiring down the windshield, if on the outside, wind buffeting might cause wiring to come loose. If running through a front door jamb, chances of leaks and paint damage would turn me off.
Drill LOT's of holes in your roof!!!
(just kidding...)
The wires from my rack run down the passenger side of windshield, stuffed in that recess, behind the "A" pillar and then smoothed over with silicone.
The guys who did my rack did a nice job. I'll see if I can take some photos.
Not sure if these help.
Do you have any pics? My fuse block is in rear and I’d like to run wiring through rear hatch. Thanks!
See post #299
Down the back door jamb, behind the notched taillight housing, ran along the frame to the sPOD source under the hood.
And again on post #766
if you are only running 2 wires for a front lightbar, tucking in the window grove works alright.
I ran 6 circuits to my roof for front, ditch, each side, and rear lights. plus a circuit for amber accent lights. the KC lights wire hider is awesome I have 1 on each side of the windshield.
Sorry to take so long replying to you.
I don't have pics currently. My GX is covered in mud, it's dark, and freaking cold outside (28 degrees on Phoenix! WTF?!) so I'm not taking photos tonight. However the description in post #12 is how my wiring is installed.
