Hello all,
Quick one about connecting rod bearings...
I got a knocking noise in my 2H so did all the reading I could on here and rod bearings seemed the easiest to check first so I pulled the sump for want of anything better to do on the weekend.
I gave the rods a thorough jiggling and other than a tiny forward/backward movement (thrust clearance?) they wouldn't move up and down on the crank pin at all, as far as i could tell.
Obviously the clearances are pretty(imperceptively?) small but if it doesn't obviously move can I rule out worn rod bearings?
Where might i look next?
Thanks in advance
Thanks in advance
