I have a 97 1fz-fe on a stand that I obtained a while back for my existing knocking motor. I'm not doing a rebuild on it, I just want to freshen up the main bearings and connecting rod bearings while they are easily accessible. After reading the FSM and removing a couple of bearings I see that these engines have a variety of replcement bearing options. Also, after asking Beno and reading an old post from Cruiserdan I also see that there are multiple options as far as bearings in that this is a "select fit" motor. The FSM lists the schematic and where to find the stampings (if you cannot read them on the bearings) which is not as easy to see as the FSM makes it out. My question is - Are there multiple different sizes of mains and connecting rod bearings for EACH main/connecting rod in one engine or are they all the same across the engine? I need to order bearings and NO I haven't pulled them all apart yet. I'm just curious about what lies ahead as I pull the crank out. I don't see the need for a regrind so far.
Thanks
Thanks
