RIP Orangey swap time
jrmudder92
John R.
Madison, WI
Website
www.instagram.com
Yea it happed idk what to do now :crybaby: i am all sad:frown::wrench::crybaby::crybaby::crybaby::crybaby::crybaby:
What's wrong with it???
You're other thread is a bit cryptic.... you said all I have to do is injectors to I have a cylinder down.
Down how???
If the motor is truly trashed, go for an engine swap.... a gm 6.2 or 6.5 is fairly easy..... or just get another 3FE for it.... they are fairly cheap to find.
Edit.... engine swap from easiest to most difficult
Carb'd 350 chevy
6.2/6.5 diesel
4bt/6bt diesel
LSX - toyota 4.7 (these will require a different trans also)
Cost wise they pretty much line up the same also.
Down how???
Carb'd 350 chevy
6.2/6.5 diesel
4bt/6bt diesel
I just don't know what I wan to do I am at a lost I want to drive my baby
Sent from my iPhone 5 using IH8MUD
Down how???
Carb'd 350 chevy
6.2/6.5 diesel
4bt/6bt diesel
Your forgot the 5.3 Vortec
Carb'd 350 Chevy? Is it 1970 again? :)
Those vortec's are considered part of the lsx line, since everything is swap-able.
as for the car'd cheby.... didn't recommend it just threw it up there as a simple swap for comparisons sake. Not sure if that swap would even fly in NC.
start by letting us know what exactly is wrong with it and then i'm sure the collective "wisdom" of this group can point you in the right direction.
first i did hg that worked kinda then timing then it still idles rough but drives ok I thought it was a a fuel injector bad just dumping fuel in the number 5 cylinder then i did the check did not even bother doing 6
1-120
2-120
3-90
4-90
5-0
I have a leak down tester. You should really start at square 1 and see what is the actual problem. You are hypothetically spending money and time that may not be necessary. The 3fe is a tank. I've over heated twice, once with a fist sized hole in the radiator and am fine. She was designed to run with a 3fe, let's figure out what's what and go from there.
Ok I can my cruiser over there at the cars how then go from there
Just so you know it dose not over heat or nothing
