ok ive had several head scratching years of on-again and off again half-heartedly trying to sort out my horn troubles on the fj60
I'm due for an annual inspection/registration and figured I'd give it my annual attempt before crossing my fingers and hoping the inspector looks the other way.
Over the years I've attempted the usual mud-approved solutions:
- 22 brass casing
- new brass horn spring-loaded "stick" , can't remember the official name
-new brass circle ring inside the steering column
- cleaned all contact points and tried dialectic grease
- washers under the various horn buttons, contacts etc
- fuses
- new aftermarket horns
After all that I still was left with an I working horn 90% of the time, luckily it works when I really need it (LR inspection, occasionally when someone cuts me off)
Over the weekend I dove into the wiring... and I'm baffled, I have found a weird "hack" that I can't explain and I'm terrible at electrical and am intimidated.
The hack is, if I disconnect one of the two wire,either one, on the drivers side horn then it works. Doing the same on the passenger side makes them inoperable.
Having both plugged in on the DS makes it inoperable. Having both unplugged makes both DS and ps horns inoperable.
Switching the wires doesn't seem to impact it, as long as one is unplugged.. ,as soon as two wires are plugged in then it doesn't work.
What could it be? Grounding? Seems so bizarre
The good news is I'll pass inspection but I hate being dumb so must get to the bottom of this.
Any help or hints appreciated!
- 22 brass casing
- fuses
