'restoration' question
Greenfield, MA
Website
thecarpentryway.blogspot.com
After pricing out upper-to-lower cab seals and getting over the shock (@$220 for the set of three), i am planning on reusing my existing seals. They are reasonably pliable still and completely intact. i'm trying to figure out the best way of removing the old paint from the outer edges, along with the odd chunk of rust scale that is stuck to them. I'm wary of using a stripper or solvent that will damage the rubber. Any suggestions?
Armor All
I haven't had a spot of trouble, but maybe an old timer can chime in. I worked for a batting cage growing up and all the wheels and balls were rubber and we used acetone to clean them once a day with no issues.
Paint stripper works - methylene chloride type. Acetone is funny stuff - it can be VERY hard on certain plastics that other strong solvents won't damage. Test a small area.
I'd expect any solvent would remove the top layer of oxidized rubber, but what you're trying to avoid is a solvent that dissolves it completely.
