If you read my recent post about my temp gauge mod you know that I discovered my truck is running slightly hot which concerns me because in a few short months its going to be getting much much hotter here in Southern California.
My first step toward lowering the temperature is going to be replacing the original 3,000cst silicone oil in my fan clutch with a combination of 6,000cst and 10,000cst oil. I will also be measure the temp at which to clutch plate opens to make sure the spring is still operating at spec. I should mention I dont really know what spec is, but if it doesnt open by 120 degrees I'll be bummed. I'm doing all of this because I didnt want to buy a new blue fan clutch, so wish this cheap bastid luck!
The fan clutch is off the truck and sitting on my desk so I'll be tearing it apart, checking temp of spring activation and allowing to drain overnight before I refill with heavier oil and reinstall tomorrow. I'll post pics as I get into it.
