My 62 is marking its teritory in the driveway and the dogs are getting jelous, so I am going to change:
*oil pan gasket
*valve cover gasket
*timing chain cover gasket
*side cover gasket (if there is a side cover)
and it has an exhaust leak so I was going to replace the manifold gasket and make sure the manifold is flat.
While I have the radiator out and the lines drained for the timing chain I am going to put in a core heater. It also needs a thermostat.
I would prefer to only have to take everything off one time and drain the cooling system once. Is there anything else that wears out that I should replace while I have it apart and have access? Anything else, like a transmission cooler? There is nothing else that I know of but I would rather do the work now than when something goes wrong. It will also be a good bonding experience.
*oil pan gasket
*valve cover gasket
