Not to be nit-picky...well I guess I am: Its the underside of the bolt head that has the locking ridges. And along with the OEM Belleville style lock washer this is what keeps the bolts from loosening under rotating torque. This OEM mounting hardware is a brilliant example of Toyota's 'non-off the shelf' engineering that really proves itself in the real world.
For the record I have had nylock and/or split ring type lock washer system fail (loosen) apart of the rear upper control arm mounting bolts on my rig. However I've never had an issue with the OEM bolt system (as long as you don't tighten/turn the OEM bolt head end and "strip" the index/locking ridges...this is why Toyota recommends replacing the bolt/nut/washer at the same time the control arms are removed/replaced...). ALWAYS tighten/turn from the NUT side ONLY for Toyota 80/100 Series OEM rear UCA/LCA mounting hardware.
