When you guys say 'click', do you mean 'clickclickclick'? Mine clicks only once each time I turn the key, but sometimes takes up to 10 turns of the ignition before it will actually start up.
Contacts, plunger, or solenoid?
TY
Solenoid = Relay.
-B-
Huh. Most newer cars have a relay as well.
-Spike
TY,
Contacts and plunger. Allocate 3hrs for your first time doing a starter R&R. There are several write ups on how to do this and with your lift you can get to it pretty easy. Disconnect batt, 2 wires on starter (1 connector & 1 nut), 2 bolts on the starter, and snake it out. 30 min to replace the contacts & plunger (read the FSM) and the put it back in.
-B-
Yeah, those are the same symptoms my 94 Nissan pickup was showing. I did the starter first and wasted time as it ended up being the ignition switch. Easy fix on the Nissan as the switch is in the steering column. Not sure on the FZJ80, though.
