- Thread starter
- #21
I am pleased to report that with my key cylinder illumination has returned to nominal function.
And hey, look at that poor little zener diode this way: It was designed to protect the circuit. Whenever a voltage spike came along, it took it. Years and years of selfless, thankless duty in the service of the proper illumination of your ignition switch. So you could figure out where to put your key even if the dome lights were all burned out. And then, it failed. It gave it's life so that you don't have to fumble in the dark.
Clipping it's leg is just releasing it from the bonds of this mortal coil to rest in peace forever. Replacing it with a new zener shows it respect by displaying that we found it's function to be worth continuing.
There should be an IAQ for this kind of thing.
As promised, the solder side of the board:
