- Location
- Gardnerville, Nevada United States
Extremely Clean and Complete Turn-Key and even more!
Super Light Weight w/offroad lift and taller tires
Fiberglass construction thru-out - no rattling apart!
$22,500
Bed can be made up as king, queen, double or twin
Wet bath - toilet, shower, sink
2 burner Suburban range
Microwave
Dometic 3-way fridge
Range cover
Sink cover / cutting board
All lighting inside and out LED
Exterior LED colored area light mounted on Casita frame w/remote control
16,000 Btu furnace
Upgraded 25 gallon fresh water tank w/quick fill connection
Black / gray tanks
2 Renogy 100 watt solar panels w/mounted charge controller setup as portable
20’ extension cable for solar panels
TV shelf
Cable ready
Bubble levels
Fantastic Fan w/Maxx Air cover to be able to leave open in rain
Water heater w/ 3-way power source and electronic ignition
Brand new 20 gallon propane tanks
Brand new propane gas lines
Brand new propane regulator w/auto switching
Blue Sea 2” digital volt meter - constant battery monitoring
Virtually brand new deep cycle battery
30amp surge protector
New Goodyear Marathon tires 225/75/15 taller than OEM
Brand new spare - still has original label on the tread
15” Aluminum rims
Off road Hi-lift axle
Torsion ride suspension
Electric brakes
Anti sway control
2” Receiver hitch w/anti-sway ball
Electric tongue jack
Fire extinguisher
Vinyl flooring w/matching extra sections for potential repair
4” Brand new memory foam cushions and back supports to make a complete king
2” Memory foam queen topper
Fiamma F45 awning
Welded rear bumper supports w/Aluminum cargo box mounted
Upgraded scissor leveling jacks on all 4 corners
Fresh water fill hose
Fresh water filter for fill hose
City water regulator
Stack of modular Jack Pads’
Holding tanks dump hose w/extension
Trailer cover
More photos on the Craigslist ad
$22,500
Microwave
Range cover
16,000 Btu furnace
Black / gray tanks
TV shelf
Cable ready
Bubble levels
15” Aluminum rims
Electric brakes
Anti sway control
Fire extinguisher
Fiamma F45 awning
Trailer cover
