kelly saad
Supporting Vendor
I just installed a lift and came up with a technique to help remove the rear shocks. If someone has already covered this, sorry. I'm just passing on what I did myself that helped. Drill a hole in the upper section of the shock (all the way through both sides). Stick a screwdriver through the holes and use it as a lever/handle to turn the shock while the wrench is on the nut. This way you don't have to try and loosen the nut all the way up in that tight spot with your arm going numb. It also helps hold the shock from spinning while you break loose the nut. I let mine spin until the screwdriver was wedged against the sway bar bracket while I broke the nut loose.
