Removing paint from powdercoat
So I screwed up I had some surface rust on the bottom of my passenger's side rear door. I sanded it, Corrorseal'd it, and was spraying on some white (oof) Rustoleum primer and didn't cover my powder coated sliders as well as I should have. So I have some lovely white Rustoleum primer on my black powder coated slider. Anyone have a recommendation on how to get it off, without removing the powdercoating?
Thanks!
Acetone (nail polish remover) on a rag should remove the paint but not mess with the powder coat. Test on an inconspicuous area first
Thanks! I bought acetone, mineral spirits and laqquer thinner, was waiting for some advice on which to use.
Acetone & lacquer thinner should both work fine. Since powder coat is actually closer to a hardened plastic than paint, most solvents won't ruin it if just used on a rag to wipe it down. Pouring it on and letting it sit may yield different results
Powder Coat Question
acetone didn't work will try lacquer thinner next otherwise I'll live with it lol
lacquer thinner worked!
