Cruiserdrew
On the way there
e9999 said:12 tons feel much better to me...
remember these have "double" rating. Meaning the 6 tons mean 3 ton per stand...
Depends on the brand. Look at it the way you would overhead lifts. The standard is 4 times the actual load. I often have a primary set of stands, and a second set adjusted to catch the load if it drops 1/4 inch. You cannot be too careful. Use the big tires to stack under the truck, keep the floor jack in place with no load. Thats why I advised Biff to keep the rear tires on the truck.
In front, you have no choice. At a minimum you will be partially disassembling the knuckle, which makes it impossible to do with the wheels on the ground.
Do the rears first-it's easier and will build your confidence for the fronts, when you find out why the $1700 quote was not unreasonable.
