Regear questions
salt lake city utah
So i got a elocker out of a 99 limited 4runner, I bought v6 5.29s for it and a gear install kit from cruiser outfitters. The pinion splines are way too big and the flange and outer pinion bearing won’t fit. Do elockers use v6 gears, or do they use 4cyl gears? Any help would be greatly appreciated thanks!
There are early diffs, and late. Early were 27 spline. Late were 29 spline. Your solution is to get a 29 spline pinion flange. Marlin sells them. Count the splines before ordering.
Yep I got a 29 spline pinion. 29 spline flange and a new pinion bearing set has been ordered. And a solid spacer too. Thanks
