RobW0
GOLD Star
I have the 2-way Viper remote start on mine. I have not measured the current draw on it yet, but you can see that it has one by how the antenna for the system can melt snow on the windshield.
Greetings - the stealership I purchased my 200 from installed a dual battery setup for me using a RedArc unit. Based on the fact my main battery keeps getting drained and the leds on the RedArc don’t turn off when the ignition is off, I’m guessing they hooked up a constant hot lead, instead of Ignition switched.
Anyone installed one and able to provide help on what circuit/wire you tied into for the install? Hoping to figure it out without paying another Toyota shop to look at it.
TIA.
Battery is done. That much is clear from symptoms of being completely flat many times by morning. Whether root issues is phantom draw or not, the battery is still already compromised.
I hope so man, sounds exhausting.Switch Pro was set up incorrectly (since resolved), Viper smart start alarm, and RedArc unit. I'm honestly thinking it might be as simple as the main battery was drained too low during the initial build process and won't hold charge. If so, the new battery's will resolve this problem.
Since I had the truck, I've always charged the aux first then the main, but the vehicle arrived on a transport truck with the battery dead.
Optima's being replaced with Odyssey's next week, and hoping its just that simple. If not, the shop I'm taking my 200 to will resolve the problem once and for all...
I have the scanned (Carista), but do not leave it plugged in. I really am optimistic the Stealership that built my truck just killed the main battery and once I replace both the main and aux, my problems will go away. Will be nice, as I don't really trust the truck to go camping/exploring too much, for fear I'll be stuck with a dead vehicle one morning out in the middle of the dessert/mountains. I have a jumper pack from Noco, but would rather not have to carry it around all the time.Any chance you have an ODB II scanner plugged in? That alone has led to some low battery situations in my truck during periods when I haven't driven for a bit.
Is this part of the issue? Are you flatting the battery when external charging?
TIA.
