Other than finding that the blue block appears to be a later version of the 13B-T, does anyone know the real differences between the two?
I thought red block means it was made by hino?
True or rumour?
Not sure who makes blue.
lowenbrau: does this mean my 88 13bt is not sleeved? Anyone know?
Cheers,
Nick
Post 87? has the newer block which is not sleeved and has and 8 bolt crankshaft-flywheel connection rather than the earlier six. I believe this allows the use of a larger clutch disc and pressure plate ( same as the 2H )
I thought so too, till the head came off the blue block in Poo. Sleeves there are, and it was a late model donor.
Yes on the 8 bold crank vs 6 bolt. The red block shares the same crank number with the 3B.
All post 87 I have seen in BJ74's have been blue block, and all earlier ones have been read block thus far.
hth's
gb
Look at all you spoiled JDM people, discussing engine block colour! Pre JDM all we had was dirty oil coloured blocks!
Ive always thought Toyota started painting the blocks blue when they introduced the new non-sleeved block in 8/88.
I havent personally seen a blue 13bt, but ive got a red 13bt and a 14b in bits out in the shed. Ive been told by someone that has had alot to do with the 'b' series over the year that all the post 8/88 b's (b,3b,11b,13b/t,14b/t) used a common block with the only difference being the bore size.
If that is the case, it interests me that no one has made reference to the fact that the post 8/88 engines use a roller cam. These engines can be identified by the fact that they dont have a cam follower access cover behind the exhaust manifold. Instead the block is cast solid in that area, but has two rows of 8 bolts. IIRC one row has a 10mm head, the other 8mm (these are inline with the roller followers. One acts as a guide pin, the other as a stopper so the follower wont slide down its bore too far when the engine is being assembled upside down.)
It interests me because wouldnt that be a positive way of identifying a non-sleeved 13bt, or does the 'blue' 13bt still have the access cover???
I pressumed it wouldnt as a Daihatsu workshop manual i have for the b & 14b, printed in '88, has a cut away of both engines. It clearly shows both having the solid block and rollor cam.
Out of interest, i drove a Daihatsu Delta 4 ton truck last year powered by a 14b (factory). I forget the year, but '95 rings a bell.
I remember checking the engine over as it was the first 14b i had seen. It had a small aluminum plate glued to the top of the rocker cover which was just big enough to cover the cast TOYOTA in the cover (the glue had come loose enough for me to lift the edge.) The plate had 'Direct Injection' printed on it. The head and block were both painted black, but they both had a raised TOYOTA cast into them.
