Rebuilt 12HT not getting enough oil pressure??
Johannesburg
I guess that the title says it all. I have rebuilt the engine and have set it up to bench run.
I get the correct idle pressure , but it never goes up to the 3+ bar when the revs are increased.Yes, I don't like to rev it too high without a load, but it's still not getting much above 1.5 bar.
I am using a mechanical guage which flicks up quite nicely even with my oilcan providing pressure.
Tested with the turbo and alternator and injection pump feeds blocked and still the same.
It has a new oil pressure regulator piston and spring fitted, and both pump rotors were replaced with new.
The filter is not Toyota, but the Fram equivalent and I have not changed this out yet.
When rebuilding the pump, I made sure that the two rotors were lined up (two marks on the rotors) , but do not recall that they had to be in any particular rotational position, did I get this wrong??
Any clues please folks???
G
Is it actually pumping oil? Perhaps its just not priming.. have you seen oil squirting out of the pressure sender port if its open?
Ja, it’s definitely pumping, to all the ports mentioned, and enough to give that .3 bar pressure rising to just over 1 at revs where it should be 3 or over
Do you have the old pressure relief valve spring? Have you done a length comparison.. if there's not some major issue with tolerances after your rebuild then maybe the pressure relief valve is actuating too easily.
I have both the old spring and valve piston, I'll compare them both thanks.
If tolerances are all good, which I believe they are, then what is left, becides the relief valve and or a faulty filter.??
It will be a day or two, I snuck down to the family cottage to avoide the Johannesburg lock down boredom.
G.
Probably a long shot but Fram oil filter is a big red flag for me. I like @duncanrm 's idea on the old pressure relief spring too. Makes sense.
Good luck!
Anyone ever seen an " Oil flow diagram" for the 12HT??? Please pass it on if you have one.
The pressure was low and I couldn't get the oil pump gear, so I replaced the entire housing with a new one. The results have improved significantly.
If it helps, on my 2h, I have experimented with different lengths of oil pressure relief valve springs with new ones, old ones and cutting both a little , adding shim washers to lengthen. Long aftermarket and short oem valves, the oem valve can get stuck on the 2h. Frigged around a bit.
With a mechanical marshal gauge calibrated with electrical autometer measuring the same, unlikely both would be wrong at the same time.
The spring length and tension gives a dramatic difference in oil pressure. Just one coil cut from a new spring would drop the pressure down by 20+ psi. I found it to be a fine balance,
Also, quality of gauges can make a difference.
Maybe a new spring if pressure is low? Or pack a washer behind the existing spring?
Understandably low pressure would be disheartening.
Wow, new pump! How much did that cost? Nothing like a fresh virgin tho...
I also purchased the longer valves. However, the housing of the oil pump of the engine, which ran 1 million kilometers, was worn out. It was around $500.
