Build Rebuilding a 40 but no longer in a 1 car garage.
Two more sections for the inside of the rear Sil.
And the second support cut and bended
Introductietijd LAD (laminaten aided design) a new version of CAD.
Made atemplate for the horns.
As there was nothing left to use as a template I used the upper rail as a reference for my contour gauge.
Then I bolted the inner piece to the rear bumper, mounted the top rail with magnets and clamps.
To find the correct position of the end of the curve I used strings to clamp the gauge in place.
An old piece of laminaten was then used to draw the shape which I then cut with my band saw.
Not sure I get what LAD is, but the results look good. I first read it as lamentation aided design which I think is closer to my design method.
Laminate is the name for the fake wooden floorboards, instead of cardboard I used left over floorboards as a template.
Left top rail mocked up for fitting of the contour gauge.
Contour gauge in position, using thin rope for sizing
Here you see the ropes marking the contour gauge position.
How are you going to protect the inside support where it meets the outer skin from being bare metal against bare metal so it wont rust?
I’m going to create water release holes an coat before welding.
After spotwelding the seals wil be sealed and the inside coated with wax.
Wow it has been a while since I updated this.
wel not much happened on the 40, busy with work, vacation and the ever growing honey do list.
Here is the left side with the Horn clamped in place.
And the other side taking shape.
I hope to be back at it next weekend and provide some bigger updates.
Cheers,
Wow! That came out fantastic. I need to stop traveling and get back to mine.
Me too, this was the first chance I got to do something in almost two months.
Connecting the other corner and fill the overlap channel.
The ends of the lower part shaped.
Some shopping done.
A shrinker and stretcher combination.
A new stainless cabinet
And an endless sheer.
