Rear x-fer case seal
Gumby
Supamod
s-Moderator
Knee deep in hookers and gin
I attacked the rear transfer case output shaft seal today. It started leaking after the last time I went wheeling. Ordered the part with help from da man c-dan. Got some Mobil 1 75-90. Put 'er up on the hoist and dropped the rear driveshaft. There's no yoke nut. ??? >:( ???
How do I get the yoke off to replace the seal?
i thought about blindly taking off the tailshaft housing, but I don't know if it'll come off with the yoke in place.
Alldata failed me and I can't find my haynes. No FSM, I'm a cheap-ass. :-[
Anybody got a clue they can sell me?
Gumby, First is it the rear seal that is leaking?
THe speedo seal can leak and look like the rear seal is leaking.
I have not changed a seal but this is what you have to do.
THe rear housing has to come off. The housing can be removed without droping the t-case.
Clean the top of the t-case as dirt will fall into the t-case when you pull the housing.
Take apart the rear out put shaft; the VC,oil pump etc will need to be removed.
You will need a FSM to pull the seal as I haven't gone past removing the guts of the rear output shaft.
The seal looks like it comes out from the out side.
