- Thread starter
- #21
Quote: You are more likely to run into long term problems from the dealer installing the replacement part then from the current hairline crack.
X2-
Worrying about this seems like much ado about nothing. Since we all had to go look for the crack, it can't be too big an issue. I agree with the above quote. The window would probably leak air or water in half the cars fixed...if we wanted to wait for the dealer to order the parts and then wait for them to work you in.
my 2003 has a crack on the drivers side one...
Same issue on my 2006. Driver side on left side frame of pop out window - small hairline crack not all the way across, but you can see it.
If they have to replace the entire window, I will be very reluctant to get it done under warranty. I thought the trim piece would pop off and it would be a realtively easy fix, but apparently not according to other posters.![]()
