Rear Seat Belt Question (with pics),
Southern Indiana
I'm wanting to install FJ62 retractables in my 60. Which parts do I need to order?? I am especially wanting to know which trim pieces I need. HELP!!
This has been covered a bazillion times. What year and month 62?
That answer will provide the necessary infomation to determine (though you need to verify) whether the C pilar holes are threaded or not, (but holes are there) and if the hole above the wheel well is the later larger one which will acommodate the belt spindle, or the smaller earlier one which won't without modification.
If you are lucky, all you'll need is the actual belts and you can just trim the panel to expose the hole for the spindle. If you are anal, you can make or buy the panels form a later 62 instead of modifying yours.
Well, I don't know if I'd say a bazillion . .. ;)
Yeah, yeah. I know it's been covered a bunch. But I'm just looking for clarification.
I have an 84 FJ60, threaded holes are present, lower hole will not accept retractor (I will modify). The reason I'm looking for clarification is that I am able to get a Toyota part discount and was considering ordering new belts and trim pieces. However, when I look at the parts drawings it shows 2 available belts (I'm ordering the ones with the retractors in the 1/4), and multiple trim pieces. Which trim pieces do I need? Just the piece under the window or are there additional pieces? thanks in advance!!
The window trim piece and the cargo panel are different. I'd not waste a dime on new cargo panels, I'd get decent used ones or make some (diamondplate, wood, ABS, etc.)
