Rear Lower Control Links (1 Viewer)
So my rear lower links are bent, bent bad. The way I see it I have a few options.
Replace them with used Stock ones
Replace them with aftermarket, either of these options
Or Bent them back as straight as I can and weld some angle iron to the top and bottom to stiffen them up.
I am running an ICON stage 3 lift and I am pretty hard on the truck when I go wheeling. I think the lift gives me about 2.5" and I have been running the stock length arms with no issues so I do not believe I need different length ones. The drive shaft does not seem to care about the slight difference in angle.
I know you are all some opinionated mother ****ers so let me know what you all think.
The Landtank are SOLID rod, not tube, if that helps the decision. You won't bend them.
challenge accepted... Yea I am leaning that direction. For a 2.5" lift should I go with the stock height ones or the 4" lift ones?
Man why did you have to go and move. You were 80 miles from my house. I might have been able to save on shipping haha. Joking aside I want out of this state badly.
I moved the same week the pandemic was announced. It’s been hell
Yea but at least your out of California. And at least you didn't pick Portland lol.
Very happy with these.
Does anyone know if the Blackhawk trailing arms can accommodate factory bushings? What's with their $125 flat shipping rate? :oops:
Running Landtanks and they are absolutely BOMBER. Combed through a ton of info, landed on those and am extremely happy with the decision.
I'm running the SPCs. No problems. But I will say that they don't look any more 'heavy duty' than the factory arms.
If rocks are your thing, I'd recommend something else.
good input, thanks!
