Rear lower control arm brace\skid
Comparison 200 vs 300
200 7.6lbs
300 6.6lbs
They are probably the same length, 200 bushings are probably stretched a little after 270k.
I have a few more sets, if you're interested pm me.
Another comparison
22+ Tundra
8.6 lbs, larger diameter main tube and bushings. Bushings 10mm wider.
Same length and bolt diameter.
Installed. 4mm and 3mm hex needed.
Used purple (mild) loctite.
It’s easier to put the headless bolts in before assembly.
They are 1/4-20 hardware, so 1/8" and 5/32" Allen would be recommend, but as @grinchy mentioned 3mm and 4mm work as well.
I would recommend to use the loctite 243 that I supplied with the kit. This is because of the high vibration the arms will see and because of the dissimilar metals of the screws and the clamps. (Stainless and aluminum)
Purple 222 loctite should be ok. Check your torque after your next off road trip to verify.
Thanks for the tips grinchy!
Interesting, I never even thought to get the English hexes out!
Maybe an opportunity to make the tapped holes 6mm and move to metric hardware?
I think that's a good idea. Next sets I make will be metric and set screws removed. Metric screws have 90° head which allow more clamping.
Labor day sale
Couple kits left
$225 shipped to lower 48.
Quick feedback - my turbo8 skids are holding up really well. I've put about 12K miles on them this summer, a few thousand of that dirt/gravel, of that maybe 500 off road trail miles. They fit well, work as designed, and have protected my RLCA well. At first I was concerned about how close they came to the budbuilt fuel tank straps, but it hasn't been an issue at all. Thanks, @turbo8!
Thanks for your feedback!
Hey @turbo8, I beat on your RLCA skids this weekend pretty hard. I had to winch myself over a fallen tree after trying several times to get over it at various angles and use of the skinny pedal. I had the passenger side RLCA supporting the truck on top of the log as I winched over. Nothing bent! RLCAs are still perfectly straight. I think without them I’d have for sure bent the passenger side. They work good.
Awesome! I bet the community likes hearing these stories. I'm glad they worked out as intended. Any pictures?
Unfortunately no pics of me on the log.
So no action photos but here is a pic of the BudBuilt lower shock mount guard which I managed to bend closer to the shock. Other pic shows driver side which was not bent for comparison. Not criticizing BB guards at all here. It did it’s job and is still functional. Just showing how hard I was bang on it and the control arm.
Passenger side (bent)
Driver side (not bent)
Here is the @turbo8 skid. Straight as an arrow.
6th gen Bronco
7.4lbs
48.5mm diameter.
Main tube looks to be hydoformed, feels thin.
i kind of feel like that demonstrates that it is doing its job of protecting the lower mounts and the shock.
Hit the trails hard this past weekend. The LCA skids did well. You can see passenger LCA took a hit on shield but still straight. Last year, same trails, I bent the passenger LCA and had to replace.
Trail Tailor LCA skids and Bud Built shock guards also did their job.
I have more sets available on the site now. These are the updated design that use metric hardware, which allow more clamping force than before. With more clamping force, the set screws are no longer needed.
Can the older version be updated with new metric hardware?
