FJ809496TLC
80 series addict
Getting ready to find out what's causing the rear ds door not to lock or unlock. Anyone had the same issue? TIA
Two 80s, same door side, doing the same thing except one make sound the other doesn't. Most likely one is a rod and the other one could be a motor. Thanks blkprj80It may also be the electric lock motor/mechanism.
Search for electric door locks and you'll find lots of threads to follow.
My rear hatch lock had a cracked part that was easy to fix with a good degreasing and some epoxy.
The hard part is getting there. I've got a set of those red plastic prybars for trim that really help.
Good luck.
The first one was bad actuator. I haven't got a chance to check the second one yet.did you figure out your door lock?
