I am having some sort of problem with my rear door window. The arm that moves the window up and down keeps coming out of its track. It has happened twice in the last two days, and it happened once about six months ago.
This is a 93 80, with power windows.
When I fixed this on saturday, I put the arm back on the track (the track that is attached to the bottom of the window) and tested it by moving the window up and down. When I did this, I noticed that when the window reached just about the half way point, the roller on the end of the arm would hit the end of the track. In fact, the roller would go out of the track about half way before it started to come back into the track.
Make sense?
I moved the window up and down several times with the door panel off, and it never actually popped completely off the track (even though it went halfway off each time)so I figured it was probably ok. Well, it popped off again today, so I guess it was not ok. My guess is that if you stop with the window half way down the arm can bounce out the track. If you are just moving it up and down it might be ok.
Is there some sort of adjustment to stop that? I thought about trying change the position of the track on the glass, but that would require taking the track of the glass-- and I am guessing that it would be a pain.
Jared
PS-- this is like the third problem I have had in the last week. I swear, my 80 is having some sort of nervous breakdown.
Make sense?
Jared
