Hey all,
I recall drttduck had this same issue a few months ago but a quick search of the archives shows no results of what he found. so I am not rehashing here this is a new problem.
the ps rear door will not open form the outside or the inside of the vehicle. I already pulled the inner trim panel off ( much easier to get off once you yank the center pillar trim out of your way) and even removed the outer handle to see whta was going on form that side. all of the rods are connected and the latch mechanism is rotating as it should. The lock is engaging adn disengaging as normal but the door will not open no matter what I seem to try. I even tried to manually engage it with a screw driver, it rotated till it hip the stop but still would not open.possible that there is something jammed in there but I doubt it.
so the question is has anyoe else ever seen this one?? also I am a little wary of pounding on the latch too hard unless I have a spare sitting next to me. I am pretty suer I could get the latch broken down to where I could disengage it but I am very sure it will not work again after I try that.
just looking for your thoughts here guys,
Dave
Dave
