Rear door glass replacement? Need help?
Wilmington, NC
Need some direction on replacing the rear door glass. Lots of scratches and found a nice one that I want to swap.
I’ve gotten this far, but have no clue how to get to the window mechanism.
Can’t find anything on a search.
Thanks guys!!
Undo the bolts on the regulator that hold the glass in the run of the regulator hold the top of the glass and pull out
I just went through this replacing the window runs and motors. There are 3 or 4 bolts that hold the regular onto the body of the door. Once you have them loose, you can use the lower right and middle left holes to reach in and catch the window/motor when it falls. To get the actual window out, you'll need to remove the small little triangle window. Up on top of the door frame where the door rubber is, there is a small screw that needs to be removed that holds the middle frame in between both windows. Once that is out, if I remember right, there are a couple more screws/bolts that need to be removed before you can take out the triangle window and then ultimately the large window. Hope that helps.
Yes, the belt molding clips are still available separately from the molding itself. I have several new in the package. I’m on the road so providing a part number right now would be impossible.
Figured it out with everyone’s direction. 30 minute project - easy peasy!
Thank you!!
