Performing a brake bleed on a 2007. The front caliper bled perfectly, the back barely had any fluid come out. There was some junk clogging the bleeder screw but we got that cleaned out. Went to the next back one and same deal, very little fluid coming out.
Procedure:
1st try went around and pumped the brakes with little bottle half filled with fluid and a tube stuck in it.
2nd try: hooked up vacuum to a brake bleeder bottle from harbor freight and fluid is coming out but more air than fluid.
It isn’t coming out in a stream of fluid like it should. Picture is of vacuum bleeder tool.
Any ideas?
Procedure:
Any ideas?
