[FONT="]I couldn't find this on Mud. Thanks to Aaron (Mr 2FE), he put this together some time back. I have had several questions about reading the check engine light on a 3FE lately, so here it is. I'll be adding it to the FAQ.[/FONT]
[FONT="]
[/FONT]
[FONT="]Get a Haynes, Chilton’s, or a Factory Service Manual (FSM)[/FONT]
For the FSM call Toyota Publications @ (800) 622-2033
How do you retrieve the codes?
It’s easier than you think. Follow the following steps to find out how your engine is running.
The codes are in your manual.
[FONT="]
[/FONT]
- Initial Conditions:
- Battery voltage 11 volts or more
- Throttle valve fully closed (TPS IDL points closed)
- Transmission in neutral
- Accessories switched “OFF”
- Engine at normal operating temperature
- Turn the ignition switch “ON”. DO NOT START ENGINE
- Using a jumper wire, connect terminals TE1 and E1 of the check connector.
- Read the diagnostic code as indicated by the number of flashes of the “Check Engine” warning light.
