When I had my FJ45 driveshaft retubed, the balancing process made it so that the zerks were no longer aligned. Not really a problem, but something that can happen if things are redone. They made very clear marks so I'm assured of proper assembly.
Mark W said:On a Cruiser driveshaft, the only reason it will need balancing is if the shop did a poor job of making the shaft. If it is straight, it will not need any balancing. I've had about 5-6 dozen shafts made in the last few years. My driveshaft guys (two different shops as tme went by) and I, do not accept non-straight shafts and have never used a weight on any of these.
Mark...
IDave said:When I had my FJ45 driveshaft retubed, the balancing process made it so that the zerks were no longer aligned. Not really a problem, but something that can happen if things are redone. They made very clear marks so I'm assured of proper assembly.
ranger said:I bet none of those shafts were made at Youngs!
They thought I was crazy when I brought up the concept of balanced driveshaft with no weights.
FLYINGLOW said:Zerks shouldn't be aligned. The zerk should be in a postion so that that part of the u-joint is in compression in forward gear. This makes the u-joint strongest.
PabloCruise said:Sorry I am a little slow this morning - can you elaborate what you mean, or better yet, show me a pic?
Wait a minute - are you one of those whacky Canadians we met at CM'05? How are things up north, eh?
