ran great, now cannot start
Hello, I purchased an 84 BJ60 3B diesel in vancouver recently, ran nicely on my drive back to Fort McMurray however I cannot get her started.
Installed a new set of glow plugs, oil pan heater, changed the fuel filter and bled the filter, rail, and each injector. installed 2 1200 cold crank batteries. She cranks fast and has fuel to the injectors. Still won't start. Checked for power to the glow plugs and seems to be right, initial higher voltage with a drop to after glow. Never had troubles starting her in the warm, problems have only started when it hit -30. Its warmed to -10 now. With the block heater and oil heater im confident its warm enough.
Any hints, tricks, suggestions or questions? would be greatly appreciated as I'm not understanding why it won't start. could the new glow plugs not be sealing completely and causing low compression? they are not in very tight as the torque specs are pretty low, but installed in spec.
I tried a little starting fluid but didnt like the sound it made when it ingested it.
thanks for your time, -Dex
you might want to post this in the diesel section.
i re-posted this in the diesel section, ill remove this if i can
I think its your ground on the starter
