Neat... but you won’t need the traction bar with the 63’s if you’re using the right 3/4 ton springs. Extra weight.
You should start with a sway bar in the front first instead of the rear. Why do you need quick connect fittings?
What shocks and valving are you starting with for the rear?
A lot of work to use radius arms when with the same amount of effort you could have a bind-free and caster-controllable 3-link.. whatever though. Looking forwards to how it performs.
We'll see how it drives before adding the front, but pretty sure I'll have one. I am typically loaded very heavy in the rear with gear and food for long trips, so it makes sense to control the rear sway. King shocks/bumpstops all around. Valving is being set up by the provider. I considered a 3 or four link setup but wanted to give this a try first since it is more straight forward. My 80's manage the Rubicon just fine with radius arms and I like their street manners. Changing out to a linked suspension is still an option. As for the traction bar, I disagree. The 3/4 ton 63's that I'm running sit nearly perfectly flat when the truck isn't loaded. between my turbo diesel, H55F first gear and Black Box second transfer case, a lot of torque can be delivered to those springs either on or off the trail. As is often done in Alaska rigs there will also be air bags in back to help keep it level as load is added. As for quick connect fittings, it's goes on and off the trail enough that having an easy disconnect of the sway bar is a good thing. I do the Rubicon a couple of times a year, and also longer 'overlanding' trips as well.
Converting a 60 front to radius arms seems like a great idea. I would probably look into Bronco radius arms though rather than 80 arms. Bronco arms seem to allow a ton of flex and their are a ton of aftermarket options.
Interesting thought. From what I understand about about radius arms I would think that longer arms would contribute the most to better flex - maybe the Bronco's are longer.
Interesting concept and awesome parts. Got any pics of how you packaged the coilovers?
The coilovers haven't arrived yet. The plan is to use the compact (shorter end caps) 12" units from King.
