Radius Arm Fasteners (1 Viewer)
Australia
Hi All
I am looking to replace the bushings in my father's 80 series front and rear radius arms. The thought occurred to me that the bolts and nuts should probably be replaced as well. However the exploded parts diagram on Amayama shows two types of bolts and nuts(parts no listed below). Is this correct?
90119-16003 - Bolt
90105-18006 - Bolt
90170-18007 - Nut
90179-16015 - Nut
Any help is much appreciated.
Thanks
Not sure if the AUS market cars are different but for a USDM LX450 I used the following:
Radius arm rear nut x290170-18007
Radius arm rear washer x290201-19011
Radius arm rear bolt x290105-18006
Radus arm axle nuts x490179-16015
Radius arm axle bolts x490119-16003
Hi All
90119-16003 - Bolt
90105-18006 - Bolt
90170-18007 - Nut
90179-16015 - Nut
Thanks
When you're doing the work, be sure to only loosen the nut or the bolt that does NOT have the four raised biting marks. They'll be on the flanged bolt heads or flanged nuts and they do a great job of keeping the torque values. But if you turn them then they lose their grip. I think pics of them are floating around here somewhere.....
