Radiators!
Check you the Champions... Toyota Land Cruiser Radiator (70-80)
They have many options. All are aluminum, you can add elec. fans, shrouds, overflow tanks, aluminum hoses, and polishing service. They have good reviews from what I have seen. 4+ stars on Amazon, Jegs, Google, and Summit. Just the 4 row radiator with no add-on is $270. That's a good deal I spec out a fully loaded one (fan, aluminum shroud, overflow, and hoses) for $584.
4-row may be overkill for a little 2F, but I don't like taking chances when I don't have to.
Had a brass four row back when the stock six was still running.
Could go over the grapevine in the hottest part of the summer pulling a travel trailer and the temp would barley touch the 200 mark.
It was fun passing all those newer vehicles along side of the road with their hoods up.
I am satisfied with the aluminum Champion 4 row I have now. It keeps the V8 cool in the summer.
Has anyone here ran across the radiator that’s an inch wider than the typical 40 radiator dimensions? The cradle is different as well as shroud.
I have an Australian import 1983 Troopy And I’m thinking it was fitted with a larger radiator. This truck doesn’t have AC but I have heard there’s a different one for later model trucks with air-conditioning.
I mounted up a older radiator cradle from a 74 and fitted the new radiator for now but I’d like to find the correct one.
Champion 4 row is wider than stock. That might work for you.
